One ui optimizing Animation problem
(Topic created on: 02-05-2026 09:31 AM)
BYNRMLS
https://www.reddit.com/r/oneui/s/phNfUmn554
Is there a way that One UI can fix this lagg problem? Like just opening the quick panel, or opening notification panel, or swiping from landscape app to homescreen. One UI seems to be very bad at it. Sometimes when I swipe the quick Panel, it is start to lag, like it take time before it open the quick panel. Not also that, but it will skeep the Animation which is just pretty annoying.
Same as swiping to home. Samsung only managed to optimized where you can in and out animation through an app which is very impressive cuz they struggled optimizing that for a long time.
Is there any possibilities to make their whole UI animation to be more consistent? Like when I randomly exit from a landscape game, it will take its time to home and it will likely skeep the animation.
Same with swiping through notification panel and quick panel.
And it mostly happen when you are in Landscape mode. But it also happen in portrait mode also. Is there a chance for one ui to be optimize with that?
Click the Reddit link for you guys to see what I mean.
2 REPLIES 2
Haisley
Thank you for sharing your detailed feedback regarding One UI performance and animation consistency. Your observations are valuable, and we sincerely regret the inconvenience this has caused.
Our development teams continuously work to optimize One UI for smoother animations and overall performance. In the meantime, we recommend the following troubleshooting steps that may help improve responsiveness:
1. Update Software:
Ensure your device is running the latest One UI and Android updates, as performance improvements are regularly included.
2. Wipe Cache Partition:
Power off your device → Hold Volume Up + Power → Select Wipe Cache Partition.
This will not delete personal data but can resolve post-update lag.
3. Reduce Animation Scale:
Go to Settings → Developer Options → Window/Transition/Animator scale and set to 0.5x or off to minimize animation delays.
4. Optimize Device Performance:
Navigate to Settings → Battery and Device Care → Optimize Now to close background processes that may cause lag.
5. Samsung Members Diagnostics:
Open Samsung Members → Support → Diagnostics and run performance tests to identify potential issues.
BYNRMLS
Don't want this undefult settings just to get consistency Animation.
I want One UI animation to be a lot consistency in just defult settings.
