Highlighted
Just wanting to know instead of using the wired fast charge for the s20+, can I plug in that fast charger into the wireless pad? Would it charge the phone faster than the previous one. Thanks
3 Comments
Highlighted
no it would just charge to whatever the specs are of the wireless charger, so if you had a fast wireless charger then it would be fast (still not as fast as wired charging) if it was a normal wireless charger then it wouldn't change, plugging in a faster charger doesn't effect the wireless output
Highlighted
thanks Habsfan
Highlighted
Hi czamek1980,
Each and every accessory has its own specifications. Samsung always recommends using the products with the provided original accessories only. It gives better device performance. Otherwise, there will be misbehavior of the device if you use the one accessory with the other.
Thanks to Habsfan for your information.
