Power saving
(Topic created on: 02-19-2024 08:08 PM)
S24newbie
Hi guys. Whenever I switch on power saving mode, the Internet will immediately changed from 5G to 4G. Is this normal? And why is it so?
3 REPLIES 3
GunasamssYT
Hi, for 5G to keep running on power saving mode, you need to go to the power saving settings, disable the option *Turn Off 5G*,and try turning back on the power saving mode. Hope this helped you 😃 1708345152471.jpg
Thank you. Have the same question and already got answer from your comment.
GunasamssYT
Your welcome :)
