Replacing of battery
(Topic created on: 07-06-2024 09:37 PM)
Berts
Hi ma'am/sir! Is replacing battery on a 3 year old samsung phone can improve the cooling efficiency of my device?
Plus..
Should I purchase original samsung battery and have it installed on a nearby technician to save my money cuz it's just replacing battery?
Or
Should I surrender it to samsung service center and how much do they usually charge for SAMSUNG S21 ULTRA battery replacement?
16 REPLIES 16
butete
best direct to samsung service center
i agree, especially since the battery is a very important part of the phone
Berts
Do you have any idea on how much is the replacement fee?
Supermond
SM North Edsa service center. Battery replacement for S21 Ultra 20240720_220156_1000025476_1721484144.jpg
Berts
Hello po, ilang days/weeks po ang itatagal and recommended nyu po ba i maintenance mode ang phone? Since battery lang kaya secured ang files and data?
Supermond
Minimum 5 days daw sabi sa Service Center.. and need mo din daw i-backup mga files mo in case magka problem.. Btw, hindi ako sa service service center nagpapalit ng battery since need iwan sa kanila yung unit.
Berts
Pwede ko po ba malaman kung saan kayo nagpa-replace and kumusta naman ang unit?
Supermond
sa Euphoria Cellphone and Laptop Repair ako nagpa replaced ng battery.. since hindi orig samsung battery, parang medyo mabilis pa din ma lowbatt. Check mo nalang muna lods sa Device Care ng phone mo if for replacement na yan. I think accurate yung data dun.. For reference, check mo battery health sa Device Care:
Status Battery
Good 75% and higher
Normal 55% to 75%
Bad 55% and lower
Berts
Weak po kase ang battery status ko, so saan po sya mag fall?
