reset phone... same problem
(Topic created on: 04-05-2019 06:47 PM)
mumbles1
Hi guys and girls.. So after much deliberation to reset my phone.i did and set it up like a brand new phone. But my messages are still out of order.i give up
9 Comments
HannaSzakacs
please tell me there is a way to fix it this drives me INSANE literally avoid texting half the time because if this problem
mumbles1
but picture messages come in fine
mumbles1
I reset the app cache and storage,reset network settings,,reset the partition cache.made sure I set the clock to auto,made sure the messages weren't pinned. called Samsung and used the online help and sent them pictures and told them off the 100s of web pages about this problem and all they could say was I must have dropped the phone
mumbles1
did that too
Hi guys, just a thought. I maybe wrong. Text message features provided by carriers. Even thou when their network have problems (like few weeks ago), users not able to send or receive text message.
If the text messages orders are wrong, is it because some text messages receive first and some messages delay? Do you guys think this is carrier issue? mumbles1 already factory reset the phone and messages still out of order, carrier issues, right? Just my 2 cents...🤔
@mumbles1 Yeah I agree with @Tallman - It's almost certainly a Network time issue somewhere - I'm pretty sure that you said that you spoke with your Carrier's tech support - But if it was the 1st level of tech support - They aren't always the most knowledgeable - They are more equipped to tell people how to Reboot or Factory Reset a device than any actual problem solving... Might be worthwhile to call your Carrier's tech support & ask to speak to a supervisor... who hopefully has more knowledge 😉🐧
mumbles1
if I use Google messages it works fine
mumbles1
could be
mumbles1
a quick Google search will show you thousands of people all over the globe with the same problem
