S20 Battery
(Topic created on: 09-26-2023 12:27 PM)
AJ27
Not a good sign. I did post my last phone diagnostic and it did say the battery is weak.
8 Comments
I'm not sure where or why you came up with this, but there is no sign here that says the battery is weak. That amount posted is indicating the use time that is left before you have to charge your phone again.
AJ27
I guess I'm hoping someone could tell me I missed regarding battery life other than the Power Saving Mode.
You need a battery replace service either from Samaung Experience Store or Samsung authorized repair shop.
RedDogRabbit
Have you run the Diagnostics for the Battery, to see what it's actual health is?
Open the Samsung Members app & Click on Support & Phone Diagnostics. Run the Diagnostics for the Battery & see what it says.
Maybe the battery is fine, or maybe it needs to be replaced. Right now, based on the information you provided, there's no way to know.
AJ27
It says weak.
I have noticed the battery draining a bit faster for some time. And I haven't been able to use the charging cable for awhile.
RedDogRabbit
Did you run the Diagnostics for the Battery?
Are you using wireless charging, and why aren't you using Cable Charging, USB cable or USB port issue?
Like I said, maybe there's nothing wrong with your battery.. maybe there is. More details would be helpful.
AJ27
Yes I did. I was prompted a few months ago. That's how I knew I have a battery problem. Screenshot_20230926_221955_Samsung Members.jpg
Helenna
Hi, I request you to perform the steps in the given link then check the performence of the Battery.
https://www.samsung.com/ca/support/mobile-devices/what-to-do-if-the-battery-of-my-new-phone-seems-to...
