BanyakGaul
06-07-2020 12:01 AM in
Galaxy SHow to enable 120Hz and Medium power saving using Bixby Routines
- Launch Bixby Routines on your Galaxy S20.
- Tap the + button in the upper-right corner to create a new routine.
- Select Start button tapped as your If condition.
- Select Medium power saving as your Then task.
- Tap Done, name your routine, and add it to your home screen when prompted to do so.
Next you’ll want to make sure 120Hz is enabled on your phone (from the Settings » Display » Motion smoothness menu). Once done, go to the home screen and tap the Start button you’ve just created using Bixby Routines. Then turn the screen off for 5 seconds, wake the phone, and you should have both 120Hz mode and Medium power saving mode working at the same time (you can confirm that power saving mode is active by dragging down the notification shade and checking the Power mode toggle).
