S20 plus Screen problem
(Topic created on: 11-24-2021 08:45 PM)
Samdom
Anyone else experiencing this problem ? Vertical pink line on the screen suddenly, after all phone was not dropped or get hit.
11 REPLIES 11
kelvinloo96
Go change screen or change phone. Quite a common "disease" for the S20 series.
PenangMan
Sounds scary.
kelvinloo96
Lol 😛 it is. Have to use money to cure it or buy new ones
Ekbp
Apply to all models start from note9 onwards. I'm quitting samsung brand now buying Huawei. Now still using my sad note+ yellowish screen replying here
faizfahmi
i'm afraid that you have to replace your screen
C-l-l-D3ITY
Line aku di tepi. Kau punta ditengahScreenshot_20211125-120020_One UI Home.jpg
PenangMan
X nampak dari screenshot.
C-l-l-D3ITY
Baru aku tau. Tapi mmg ada kat tepi kiri.
Subhajit94
Beginner Level 4
Even I am facing the same issue in my 1.5 years old s20+. Service center told me to replace the screen and it will cost around 15.5k INR.
