AbhiG
11-12-2022 10:49 PM in
Hi I have been using this galaxy s20fe 5g for a full year now, and I have come to notice that since the android 12 update, my battery has been draining really fast. When my device was running Android 11, the battery drain was much slow. Is it a problem with Android 12 or is it just my device that has problems?
- Tags:
- Battery
2 Comments
bqgc
11-22-2022 09:26 PM in
All re draining since new updates keep on spoiling the life span of each samsumg phone used for one or lesser
I hate samsumg
Better change to no wifi using an dose more 80 to 100 to 120 ghs of dqtq which is how singtel earns subscription
Phone eat man and data cos tcquse more inflationary etc
Better dun sure apps to msgf or video or jus use normal old phone or use public slot or card phone help help
I hate samsumg
AbhiG
11-22-2022 10:35 PM in
So it's only a problem in android 12? Also will it getter with Android 13?
