03-13-2021 02:02 PM in
Galaxy SI've been experimenting a lot with the camera on my S21 plus, and am noticing that the auto focus is amazing in the regular photo mode, but when I switch to pro mode, auto focus doesn't really focus a majority of the time; the photo almost always stays blurry unless I manually select what to focus on before snapping the shot. and yes, I cleaned the camera prior to using it.
I've tried to configure pro mode settings like ISO, aperture etc. and none of it seems to make a difference. I've tested it in both bright lighting and low light conditions and auto focus just doesn't focus.
I've also been through the settings multiple times and have tested it w/ the tracking auto-focus on and off and still have this issue. I don't see any other settings that could relate to auto focus, unless there's something I missed please let me know your thoughts.
is anyone else having this issue? I also updated my phone to the latest system update and all my apps are up to the latest versions.
Solved! Go to Solution.
03-13-2021 02:13 PM in
Galaxy S- Power off your phone
- Press and hold Vol down and power key until you are in Recovery mode
- Release both keys
- Use Vol up and down to navigate
- Use Power key to confirm
- Select Wipe Cache Partition
- Select Reboot system
Test auto focus again.
- Release both keys
03-13-2021 02:41 PM in
Galaxy Sthanks! it was actually the volume up key but I managed to wipe the partition.
tested the pro mode again and the auto focus while set to multi is working better now, though still a bit off at times. I guess the multi area auto focus needs some work.
Also tested the centre auto focus and it also works perfectly now, I guess I'll stick to that until the multi area is improved further hopefully. thank you!
03-13-2021 03:04 PM in
Galaxy S- Mark as New
03-13-2021 04:06 PM (Last edited 03-13-2021 04:06 PM ) in
03-13-2021 02:41 PM (Last edited 03-13-2021 02:42 PM ) in
Galaxy SHi, if @Tallman's solution don't work , i suggest you to read this post in US forum...maybe we have'nt receive this update yet ?!
03-13-2021 02:46 PM in
Galaxy Sinteresting, thanks for sharing! I looked through those posts and it seems like the multi area auto focus in pro mode certainly needs some work. some of the descriptions of the issue in that link sound very similar to what I was experiencing. if I set the auto focus to centre area, it works perfectly fine. guess I'll stick to that for now.
03-13-2021 02:43 PM in
Galaxy SHi Kya_art, Please try the resolution provided by Tallman and check if the issue got resolved. It is recommended that you do not position subjects within too close distances from device to take clear photos, and keep the proper distances between device and object.
05-07-2021 08:43 PM in
