04-06-2021 03:15 AM in
Galaxy SHi All,
Anyone else experiencing GPS issues? I am facing this on Google maps and waze. GPS signal will be lost after a few minutes and the phone will just search for GPS. I have tried various fixes recommended like switching off 5G, rebooting, switching off and on location services.... to no avail.
Solved! Go to Solution.
- Tags:
- GPS
12-02-2021 05:57 AM in
Galaxy S- Mark as New
08-09-2021 12:39 PM in
Galaxy SI reinstalled maps, Andriod auto and cleared cache to try to fix it. I finally turned off battery optimization and power saving mode and it works!
I don't ever recall changing any settings before. 🤷
Try and turn off app optimization for anything related to maps and connection
09-10-2021 10:35 AM in
Galaxy SI had the same issues so I ran a couple of tests and I think I have solved the problem. I was using a magnetic phone holder but tried a clamp type holder, the GPS worked perfectly! Plugged the charger into the 12v socket just behind where the phone was, GPS lost! Plugged a long charging lead into one of the rear USB sockets, GPS works perfectly again!
So the solution is non magnetic phone holder and charging socket away from the phone.
09-19-2021 03:58 PM in
Galaxy SYep same here. Really wish my S9 had not blown up. Long time Samsung user. This is my forth or fifth Galaxy, but it appears, I may have gotten a downgrade. My S9 had very very accurate GPS and my timeline accurately recorded not only location, but routes taken. New S21 misses entire days and when it does work, my timeline looks like I am flying in a plane, with no route info. Yup I am convinced this is all the S21. My S9 worked perfectly until the battery swelled and blew off the back cover. Same cars. Same neighborhood. The ONLY difference is my shiny new S21. I expect Samsung will blame it's customers. Too bad. Guess maybe time to consider a different brand.
09-27-2021 10:30 PM in
Galaxy SHi, I have been having the same issues since buying my S21 Ultra. Using Google maps and trying to navigate to a destination I get GPS signal lost.
I find it unacceptable that a manufacturer can sweep an issue under the carpet and insult a customer's intelligence by repeating the same advice. Yes, my view of the sky is unobstructed etc
10-08-2021 09:22 AM in
Galaxy SHad no issues with my beloved note9 on GPS - S21ultra in exact same spot in car. Loses connection all the time. Have to put phone on dash face up or it will disconnect. Going to try -turn off battery optimization- as it was on for GPS maps. Very annoying and not acceptable for $1000 plus phone
11-03-2021 06:34 AM in
11-19-2021 04:52 AM in
11-22-2021 02:27 AM in
Galaxy SGuys, check the Google maps app permissions, you might have set the GPS permission to allow only when using the app. Change that to always allow. My guess is, in android auto when you plug the phone in and the screen gets locked and turns off, so does the GPS, similar in other apps. Worked for me. Cheers
04-08-2022 08:40 PM in
Galaxy SThis didn't work for me. Mine was set to "always allow" and it stopped working after the April 2022 updates.
