12-01-2022 10:44 PM in
Galaxy S- Mark as New
12-01-2022 11:17 PM in
Galaxy SHello JoshRiando,
Thanks for your inquiry here.
Fast wireless charging should need a charger, cable, and accessories that support the function.
While charging, you can't enable or disable this feature on your device.
For more Charging Tips, click the link below.
https://www.samsung.com/ph/support/mobile-devices/how-to-fast-charge-on-your-galaxy-device/
For more assistance, you may contact us on our online Samsung support channels below.
https://samsung-livechat.sprinklr.com/seao/ph/index.html
If the problem persists, immediately bring your device to nearest Samsung Authorized Service Center.
https://www.samsung.com/ph/support/service-center/
Hope this content is helpful and your problem gets solved.
12-01-2022 11:25 PM in
12-01-2022 11:28 PM (Last edited 12-01-2022 11:32 PM ) in
Can you try removing the case your Samsung Galaxy S21 Ultra if its working, if not, then you can return it and ask for a suitable replacement that will work with your Samsung Galaxy S21 Ultra.
12-02-2022 05:57 AM (Last edited 12-02-2022 05:59 AM ) in
Galaxy SEDIT: These mods are useless ✌️
12-02-2022 06:03 AM in
12-02-2022 02:21 PM in
12-02-2022 05:01 PM in
12-02-2022 07:01 PM in
12-02-2022 07:13 PM in
