Resolved! Solved
S21fe battery life running on One UI 6.
(Topic created on: 03-28-2024 11:59 AM)
DanielCYP
Everything's good including the features but battery life seriously need to improved, Samsung need to be more concerned/considerate as well.
Don't see much improvement from one UI 5.0 and 5.1, except for standby mode which improved somewhat better with battery guardian activated.
GunasamssYT
For temporary solution, try keeping the power saving mode on.
9 Comments
DanielCYP
GunasamssYT
DanielCYP
Sure, thanks. The phone is already two years old, so live with it.
I'm planning to upgrade to S24FE if only Samsung wishes to continue.
I like what the most is it's cameras and screen which is satisfactory enough
GunasamssYT
True. Ohhh okay 👍
DanielCYP
Ok, tq for your help and reply.
GunasamssYT
You're most welcome. We always help members 😃 👍
DanielCYP
Yes agree.
chefkarll
DanielCYP
Your a50 is android 11 don't have this feature, battery protection. Only android 12 and above can use1711613440985_1711613440978_0.jpg
