10-18-2024 06:26 AM in
Galaxy S- Mark as New
10-18-2024 07:15 AM (Last edited 10-18-2024 07:15 AM ) in
If you're using Google Messages (which you should be).
Open the Google Messages app & Click Notifications.
Follow the screen shots.
10-21-2024 03:18 PM in
Galaxy SMy App Notifications screen does not look like that. The Notifications Categories is not there.
I used to have different sounds for different apps. I think the latest update got rid of that.
10-18-2024 07:24 AM in
10-18-2024 07:25 AM in
Galaxy STrini2Dbone,
When switching from a physical SIM to an eSIM, some notification settings might reset or change. To change the notification sound for your text messaging app, If your'e using Google messages, please refer the screenshot provided by RedDogRabbit and try the steps.
Thank you.
