Resolved! Solved
S22 Ultra Not Superfast charging- update
(Topic created on: 07-31-2023 11:40 AM)
Pupusik
Hi, in the past I have reported that my device lost the ability to Superfast charge.
Now with no changes to my device and only updates, I have noticed that there may be a glimmer of hope.
Here is the scenario where I get some SuperFast 2.0 charging speeds.
If I put my device on my wireless charger for about mins, and then connect my device via a proper cable and charger ( I have many of these and the behavior is the same ) I get charging rates of over 5000mA for about 15 to 20 seconds and then it starts to drop down to no charging. I have download a couple of apps that tells me my charging rate.
I can consistently get this sequence to work.
In some cases if I let my device go down to about 30% battery, I can get the same temporary SuperFast 2.0 charging rate.
Yes, I get the Turquoise ring color when it is super charging.
What if any apps or system services directly affect charging ?
I have also started the device in safe mode with the same behaviour. Could not notbuse the battey app to check the charging rate.
I may consider backing up the device and starting from scratch.
Any new thoughts or direction is appriciated.
Resolved!
13 REPLIES 13
Pupusik
Ok... on it... Will update shortly.. Will manually backup my photos, then remove them off the phone, should make the backup and restore quicker. I truly appreciate the time you have taken to work with me. Regards
Pupusik
Dang, the reset did not help, but the phone is faster 😉 ordered the USB port, I'll attempt to replace it this weekend
I've watched the videos a number of times. May also order the adhesive kit as well. I'll let the community know my results.
Pupusik
Here is the culprit Screenshot_20230802_093137_Amazon Shopping.jpg20230802_093031_1000023569_1690983034.jpg
frogster55
I have found that once phones start to have diffuculty to charge, they soon need replacing. I made it about 2.5 years with my last phone. The last couple days after charging overnight I only had 30% charge.
