LeeMay
Beginner Level 3
The phone become slow charging now after nov patch update. In past, it took nearv1hr for full charge, now 2hrs still at 60%++
5 Comments
Demoron
Try changing the cable. Or bend the charger cable.
UnknownUser
I am using s22 now but it still the same. You did not change the charger right? Than agree with LeeMay, you may try other cable.
scinex
Expert Level 3
No issue at all with my S22U. I guess try tp replace the cable first and see whether the problem is solved.
All the best!
keith2222
My S22U got the same issue. Tested 45w charger working well. Any solution provided?
LeeMay
Beginner Level 3
At the end I bought another ugreen cable to replace my original cable. Then the issue gone. Now back to fully charge within an hour.
