S23 Battery Drain
(Topic created on: 05-12-2025 04:18 PM)
McBacon76
Sooo...Is Samsung willing to change my battery it the UI One 7 kill my battery??
3 REPLIES 3
Day_Walker
I've got no battery drain since OneUI 7 update.
Backup your phone to external USB drive using USB-C.
Power off the phone.
Power on using power + volume up/down and in the system menu select cache and purge the cache. Reboot your phone and over the course of the next 48-72hrs calibration and optimi,Orion id enabled on your phone battery will normalize as usual.
RedDogRabbit
I've done everything that I suggest to others, which includes what you have said..
My S25 Ultra shipped with One UI V7.0, and until the April 1st Security Patch, I was getting great battery life.. but since April 1st Security Patch, and still after the May 1st Security Patch, I'm having to charge my phone twice a day... I haven't had to do this, since my Skyrocket more than a decade ago!
It's not just being reported here, but on Samsung Members US, as well as Sammobile & SammyFans.
The May 1st Update was just a Security Patch, hopefully Samsung will have figured it out for the June 1st Security Patch, which is supposed to include a variety of fixes.
Helenna
Hi McBacon76,
That's sad to see that your Galaxy S23 battery is draining fast after the recent software update. We understand how important battery life is for a smooth experience, and we’re sorry to hear about your concerns with One UI 7. We’re constantly working to improve our software, and your input helps us identify areas for further refinement.
Please visit the link given below and check if it helps to solve the battery draining issue on your device.
https://www.samsung.com/ca/support/mobile-devices/galaxy-phone-get-the-most-out-of-your-battery/
Thank you.
