abduhalwi
Is it just me or because of the latest S23U update, now I notice my S23U battery drain a bit fast. Tested few night leave phone in airplane mode without any connection, battery dropped around 3-4%. Duration time around 11pm - 6am. Before this not like this. Anyone have same issues?
13 Comments
vyan1105
🤔🤔🤔🤔 Do u know how to send error report ? Can send log file through member error report at "support"
abduhalwi
Thank you for suggestion, now doing.
Edster89
It is the update ur not alone in this. I don't think its the phone problem. Try this tips as in don't turn ur AOD on often instead only tap when u need it. Performance mode keep it under light/ lite mode. Also ur display try toggle to fhd+ instead WQHD. Use WQHD if ur using full media usage at that time and ur near a charger.
Hope it helps. I know this method did it for me
abduhalwi
Thanks for the tips! Hopefully Samsung address this issue.
ericplong
Brother 3 4% ok lah. Fligh mode the phone also is still on mah.
abduhalwi
ok bro, just want to verify 😅
scinex
Expert Level 3
3-4% is indeed, normal for whole night.
Zimanev
3-4% personally for me not a big drop. Phone is still running despite being in a flight mode.
abduhalwi
Ya, but my normal is 1-2% drop, 😅 based on previous usage, anyhow hopefully this is not serious issues
