02-28-2023 06:21 PM (Last edited 03-01-2023 03:24 AM ) in
Galaxy S- Mark as New
02-28-2023 08:38 PM in
Galaxy SHello AiBun,
We appreciate you sharing the screen shots of your new Samsung Galaxy S23 Ultra and your inquiry on how others have experienced the performance of its battery.
While your beloved Samsung Galaxy S23 Ultra packs the same 5000 mAh battery as its predecessor, it has improved a lot in terms of battery life and endurance this time around.
Surely other members will comment similar experiences and would like to know and hear about their own feedbacks here.
02-28-2023 10:16 PM in
03-02-2023 08:15 AM (Last edited 03-02-2023 08:15 AM ) in
Galaxy SBut still depends on your usage
03-02-2023 03:56 PM in
Galaxy S1. Performance is standard
2. Brightness is at 30 to 40%
3. Refresh rate is adaptive
4. Display is at fhd+
5. Bluetooth is always on and connects to my watch
6. Precise location always on
7. Data is always on during work (5g enabled)
8. Sync is always enabled
9. AOD is tap to show
How about your settings? I'm only getting 5 to 6 hrs screen on time with this.
03-02-2023 06:03 PM in
Galaxy S1. My performance is at light mode.
2. My refresh rate is standard
3. I rarely use my location so its always off most of the time
4. And lastly always on display, I think its the culprit draining my battery on my case, since I was using it before and I can only get 3-4 SOT from 93% to 40% battery life but after I turned it off I can get 8h+ SOT, try turning it off completely
03-03-2023 04:08 AM in
03-03-2023 05:24 AM in
