02-01-2024 06:33 AM in
Galaxy S- Tags:
- Battery
02-01-2024 06:37 AM in
Galaxy S- Mark as New
02-01-2024 06:43 AM (Last edited 02-01-2024 06:45 AM ) in
Galaxy SIf you only just got it, give it a day or two for the Battery Software Measurement to figure out your usage.
My S23 Ultra averages between 1% loss over 11 to 20+ minutes.. but it depends on how you are using the phone, Mobile Data vs WiFi, Sleeping Apps, Apps Optimized or Unrestricted, SOT etc.
I'm averaging ~ 7+ hours of SOT.
12-11-2024 09:37 AM (Last edited 12-11-2024 09:38 AM ) in
Galaxy SWhat application are you using to see the battery discharge speed?
02-01-2024 10:42 AM in
Galaxy S Hi, Don't worry it will take some time for your new device to learn your usage pattern or behaviour to optimize its battery life. It may take several weeks to a few months to fully optimize the battery.
Also to learn more about the "Battery" please follow the steps in the given link.
https://www.samsung.com/ca/support/galaxy-battery/about-battery/
02-01-2024 11:51 AM (Last edited 02-01-2024 02:45 PM ) in
Galaxy S"several weeks to a few months"???
Try less than a week!
Where are you getting your information from??
The link you posted, has nothing to do with "Battery Learning Usage Patterns", it's about battery decline & how to diagnose a dying, or dead battery..
Seriously, you should delete your post... or at the very least, edit the living daylights out of it.
Wonder how long my post, and the Moderators post will remain..
02-08-2024 03:37 AM in
Galaxy SI've noticed this as well, I just bought the phone and it gets unnecessarily hot and gives me like 2 hours SOT with 40% usage, Idk why it's acting so erratic and hot and laggy. While playing cod mobile the entire screen was lagging and there was a lot of screen tearing. The thermals are really trash and the camera has a noticable lens shift while shifting from 1x to the 3x lens, like a barn door effect, the entire phone just feels off and everything is sub par with the reviews I've seen and heard. I Shouldn't have taken the exynos version....
03-05-2024 09:19 PM in
Galaxy SExactly same issue even I'm experiencing. Before this s24+ I was using a A52 from past 3 yrs. Because of slowness I bought the flagship series and now facing this issue. Why can't they test the product thoroughly before releasing it.
It's been 12 days since I bought the phone and I think it's enough for the phone to learn my battery usage patterns.
