S24 Ultra Battery Life
(Topic created on: 06-09-2025 09:22 AM)
prashT
My S24 Ultra Battery Life is very bad after the One UI 7 update. I hoped Samsung will fix it on May update but they didn't. Will it be fixed in June update?
1 REPLY 1
Helenna
Hi prashT,
We understand that the battery life on your Galaxy S24 Ultra has been significantly impacted after the One UI 7 update. We'd like to assure you that Samsung is actively working on improvements.
In the meantime, we recommend trying the following steps to help mitigate battery drain:
  • Use Device Care to optimize battery usage
  • Disable unused features like Wi-Fi, Bluetooth, and location services when not needed
  • Adjust screen brightness and screen timeout settings
  • Monitor and limit battery usage of background apps
  • Consider clearing the system cache partition (safe and often effective)
If the issue persists, a factory reset after backing up your data can sometimes help as a last resort.
https://www.samsung.com/ca/support/mobile-devices/back-up-and-restore-data-on-your-galaxy-phone/
https://www.samsung.com/ca/support/mobile-devices/reset-your-samsung-galaxy/
If you have any other questions or need further assistance, feel free to reach out.
Thank you.
