S24 Ultra gracing fast battery drainage issue ?
(Topic created on: 02-12-2024 07:17 PM)
phantomCrimsonذX
Is it me or anyone with S24 Ultra gracing have  fast battery drainage
5 Comments
Born2fly
I don't see battery drain but I do observe slow charging. It takes long time . Even with samsung charger it different each time.
Fatwa
Mine is staying quick, but it's just day 2... so.... normal.
GNine
No issue here
Samsung_Ben
Hi phantomCrimsonذX, you may experience that the battery drains quickly for a few days/weeks after using the S24 Ultra for the first time. It is a sign that your smartphone is still learning your usage behaviour, so please check again if the battery performance improves after a while.
Kindly also check if any apps drain the battery quickly.
Helenna
Hi, You can also check the below link to learn more about the Battery.
https://www.samsung.com/ca/support/mobile-devices/galaxy-phone-get-the-most-out-of-your-battery/
