S7 edge SD card not ejecting
(Topic created on: 04-24-2016 08:19 PM)
steel1
SD card ejects and mounts when I have no apps moved over to it. As soon as I go to applications and move an apps storage to the SD card, it no longer responds to eject or mount. When I move the app back to the internal storage the SD card ejects and mounts again. Could you check your phones and see if your having the same problem. What's the point of having the SD card if I cannot move storage over to it and not be able to eject my card.
2 Comments
Rod
i dont have this issue. but latest Samsung update may fix it. try it.
also make sure app is not open when ejecting.
steel1
I have done the latest update. Also made sure the app is not running when I try to eject. I even did a factory reset. Still having the issue.
