Samsung S22 Ultra Smart locked
(Topic created on: 10-28-2022 03:59 PM)
Makoy1
Hi guys,
I got a Samsung S22 Ultra 12gb 256gb variant from smart. It's a dual sim variant as well and the sales lady told me that sim1 is Smart locked and sim 2 should be open line (as how it should be since I have multiple dual sim devices I got from smart). Now, I got the device, went home (because I was in a hurry at the time because I am almost late for work) and didn't insert my sim cards at the store. I inserted my Smart sim in sim 1 and my Gomo sim in sim2. To my surprise, I can only use mobile data in sim 1 and doesn't give me an option to use my Gomo sim for mobile data. I switched the sims and to my surprise, sim1 detects the Gomo sim (which I think shouldn't be the case since it should be Smart locked). I turned on mobile data and it would still give me no option to select the Gomo sim even in the settings. But I can send messages and call from my Gomo sim. Also, I get this notification on the top that I cannot remove that says, "Thank you for choosing Smart." and it can't be removed for some reason and there is no option to disable the notification since it's greyed out. Has anyone experienced this? What was the fix? Thank you.
20 Comments
Dawn24
Beginner Level 3
Hello! I'm having the same issue. I cannot use mobile data using Globe sim. Were you able to fix this?
