Samsung S23 Ultra Overheats and battery drains while watching YouTube
(Topic created on: 11-09-2024 03:35 AM)
Javsco34
Is anyone else experiencing overheating issues (almost 40 degrees Celsius) and MASSIVE battery drain (>10% in a matter of minutes) on their S23 Ultra when watching YouTube? I have Thermal Guardian installed (via Good Guardians) and it's showing unnecessarily high CPU usage and high phone temps due to YouTube.
7 Comments
raphaelguppy
it's new to discussions but will look into it,did you get the 6.1.1 update by chance?
Javsco34
Yeah I am running that version currently. It's crazy. It has happened more than once as well. In the first instance, I thought it was just me going crazy but the logs kept by Thermal Guardian proved otherwise.
oneiljm
The update 6.1 is horrible
oneiljm
Samsung a05s boots down after screen locks
Plex
How long you watch youtube like hrs ?
Javsco34
Maybe an hour.... hour and a half roughly.
Plex
I found youtube is bit heavy on the battery over a period of time. Vary the usage times and see.
