shgufran
Beginner Level 3
01-08-2021 11:11 PM in
Hi, My device Samsung S7 Edge panel is disappeared after an update. Please advise what should i have to do. I tried all possible thing but issue still unresolved. I tried to use Easy mode than change to Standard mode but not working. Please advis3 how can i unistall last update from S7 Edge ?
keagan
01-09-2021 08:04 AM in
Galaxy SHi shgufran, I suggest you please try to activate the Edge panel by going into Settings >> Display >> Edge screen >> Tap the Edge panels switch to activate it. Please note that settings and functions may vary between different models and software versions.
