Selfie camera post processing issue
(Topic created on: 07-19-2023 10:32 PM)
TS1235
I just recently got a Samsung s23+
I noticed after the recent update that the selfie camera is automatically doing this HORRIBLE post processing that I can't seem to stop or undo at all. Completely changed the shape ofy face and features, etc. I tried using some other camera apps but they're really not as good as the native camera app. None of the settings on camera nor camera assistant change this whatsoever.
 Anyone else having the same issue/know how to fix this?
4 REPLIES 4
RedDogRabbit
You can try a few things:
  • Open the Camera & go to IT'S Settings & Scroll down to "Reset Camera Settings.
  • Go to Settings > Apps & Search for the Camera & Click on it & Scroll down to Storage. Clear Both Cache & Data for the Camera & Reboot.
  • Boot into Recovery & Wipe Cache.
See if that fixes the issue for you.
Deeezzyyy
TS1235
Thanks for the comments did all that and no luck unfortunately same issue
Helenna
Hi, we are sad to hear that none of the above steps worked for you.
We would request you to register your concern in Samsung Members Application. So, that our concern team gets back to you as soon as possible.
Please follow this path to register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Also, we will forward this again to our team to get it resolved and hopefully it will fix soon.
Thank you.
