Storage issue
(Topic created on: 10-07-2019 08:37 AM)
Par65
Beginner Level 3
All of my  Gallery pictures are disappeared and I don't where they are? Photo gallery is empty.It's somewhere in the phone since it's showing my storage almost full (60 gb). In storage section I can see other folders eating all the the storage memories but how can I find other folders ? I want to make a room in the phone but nothing much to delete. I can transfer or delete  the pictures but can not find them.Please help.
Thanjs
2 Comments
do you have a SD card insteted? if so unmount it from storage settings and then turn off your phone and then remove it from your phone. insert it into a PC and see if there are any pictures on it. it could be a corrupted card but windows can sometimes check and fix for errors. also do you have any backup to Samsung cloud or Google photos? check to see if any of your pictures are on there.
lastly check your gallery trash. open gallery tap on the 3 dots and tap trash.
Par65
Beginner Level 3
Thanks Snowcat19 for your help. I found the pictures in my trash folder. I wasn't aware that, trash folder works same as PC. Also some how I deleted and all the pictures went into trash folder.
Thanks again for your help. 👌👌
