10-18-2022 11:04 PM in
Galaxy S- Mark as New
10-19-2022 02:42 AM in
Galaxy STry using a different USB cable & or Charging Block. If that doesn't work, if it was my device, I'd check the USB port & Battery using the Diagnostics on the Samsung Members app. If there are no errors, then I would backup my device with Smart Switch & Factory Reset.
That's my one coffee answer.
10-19-2022 08:10 AM in
Galaxy SHi Maxfk24, as suggested by RedDogRabbit kindly check with different cable and verify if your fast charging is working.
Also, please make sure to use Samsung-approved charging devices. Samsung accessories are designed to maximize the battery life for your phone.
10-19-2022 08:19 AM in
Galaxy SToo bad that Samsung no longer includes the Charging block....... for "environmental reasons".. 🙄
10-20-2022 06:34 AM in
10-25-2022 06:15 PM in
10-25-2022 06:23 PM in
