USB Issue on S23 Ultra
(Topic created on: 11-21-2024 09:08 PM)
dong28
My S23 ultra keeps getting this moisture detected notif whenever I charge (type c to c cable is from samsung) after updating to latest patch. Sometimes it charges but when I check batteryguru app, i changes from normal, to slow to fast (not superfast charge anymore). It is annoying already since it took 2-3hrs of charging just to fully charge my phone. Is this really a bug or should i send my phone for usb port repair?
8 Comments
TeamGalaxyJustine
That’s definitely frustrating, dong28😟The Samsung Members app has a diagnostic tool that can help you check the overall health of your device. It might show if there’s an underlying issue causing the problem. Here's how:
  • Open the Samsung Members app.
  • Tap on the Support tab at the bottom.
  • Select Diagnostic.
Follow the instructions on-screen. This will help you check if there’s an issue with your device.
Hope this helps!
Try mo ibaon ang phone mo sa bigas for at least a day, then check.
Wow... a very nostalgic solution thou there's no harm in trying....
Based on experience yan... 😊
Will keep that in mind if ever I experienced same problem...
dong28
Will try it, thanks
ZiAbitong
Hi! Hows you're phone? Happened to mine just now after updating to the new software update. After i use the hairdyrer to dry the usb port it works. But im scared that it might happen again huhu.
Mine doesn't exposed to water tho
dong28
Now, it only appears once I use a non-samsung type c cable and adaptor 😓 But it is only super fast charging, no 2.0...But its ok, i'll wait for the next update patch to see if it is a bug and if not, I'll have it repaired in service center.
