Resolved! Solved
Using 2 Bluetooth devices
(Topic created on: 04-02-2021 01:20 PM)
Hammyy
Hey guys, I'm using a S21+, I read somewhere I can connect 2 Bluetooth devices?
How does that work?
SamsungJon
That's right, Hammyy! You can connect 2 Bluetooth devices to your S21+.
If you are looking to connect two audio devices to your phone (called Dual Audio), follow these steps:
1. Pair both devices to your phone.
2. Tap Media in your Quick Panel > then select both Bluetooth devices for Audio output.
And now you're ready to go!
If you would like a more extensive guide to this, please see this link: https://www.samsung.com/au/support/mobile-devices/dual-audio-android-10/
Hope this helps :)
2 REPLIES 2
SamsungJon
Hope this helps :)
Hammyy
That's so good! Thank you for sharing, gonna show it off to my friends 😛
