Voicemail help
(Topic created on: 01-04-2023 08:15 PM)
vannsgran
I have just changed from my older galaxy to s22ultra using same sim.How do I find a voicemail number?
It won't accept previous number
1 REPLY 1
Not applicable
This shouldn't be related to your phone. If you have the same sim, it should be the same number to access voicemail. If this isn't the case, I would suggest contacting your service provider.
