11-11-2025 03:52 AM in
Galaxy S- Mark as New
11-11-2025 04:15 AM in
Galaxy SIf you're streaming YouTube, delays could be related to your connection speed & stability.
You could also try going to Settings > Apps Search for YouTube & Click on it > Scroll down to Storage & Clear Both Cache & Data for the app.
Uninstalling & Reinstalling may leave data on your device, so Clearing BOTH Cache & Data should remove any remnants of the app, you could THEN Uninstall / Reinstall if you want.
You could also test Volume Up / Down with another app, ie: Spotify, Samsung music etc.
You could also Open the Samsung Members app & Click on Support, run the Diagnostics for your Volume Buttons...see if you get any error messages?
11-11-2025 04:22 AM in
Galaxy SI've cleared both the cashe and data, still the same issue.
Literally only with YouTube on the device, Not while streaming.
11-11-2025 04:55 AM in
Galaxy SIs this YouTube app or YouTube music, or both?
You can try going to YouTube Settings (the Gear icon) > Additional Settings > Toggle Stable Volume Off, or On The OPPOSITE of the current setting.
See if that works for you?
11-11-2025 05:07 AM in
Galaxy STried the stable volume toggle a couple times and repeated the other steps suggested as well, Still a delay.
Sometimes the delays are longer than others as well.
3-5 seconds to 5-7 second deslyas at times.
11-11-2025 05:24 AM (Last edited 11-11-2025 05:25 AM ) in
Galaxy SStrange.. You can try Booting into Recovery & Wiping Cache.
1) Turn off the device.
You won't lose any data wiping cache..
This MAY help, but the delay you are talking about, sounds like there might be a problem somewhere else?
Only other thing that you can do, would be to Backup your device with Smart Switch & Factory Reset..
11-11-2025 05:27 AM in
Galaxy SI'll attempt the recovery Cache wipe and see how that works.
I appreciate all the feedback.
11-11-2025 05:54 AM in
Galaxy SSafe Mode, might be helpful, except since Safe Mode disables 3rd party apps, it all depends if it thinks that YouTube is a 3rd party app or not on your device?
You could try it, if YouTube isn't disabled for you, it could help rule out if another app you installed is causing the issue?
There's zero delay on my S25 Ultra using YouTube streaming.
11-11-2025 06:01 AM in
Galaxy SHi BlkWingMC,
Thank you for reporting the delay you are experiencing when adjusting the volume while using YouTube following the One UI 8 update. We appreciate the detailed information you have already provided regarding the steps you have taken.
To assist further, please try the following troubleshooting measures:
Verify App Updates
Ensure that both the YouTube app and the Google Play Services are updated to their latest versions.
Clear Cache Partition
Power off the device, then boot into recovery mode and clear the cache partition to remove residual system files.
Reset App Preferences
Navigate to Settings → Apps → Reset app preferences to restore default permissions and configurations.
Test in Safe Mode
Boot the device into Safe Mode to determine if third‑party apps are interfering with system performance.
Submit Error Report
If the issue persists, please submit an error report via the Samsung Members app. This will allow our technical team to review system logs and investigate compatibility concerns.
We regret the inconvenience this has caused and assure you that your feedback is valuable in helping us improve the user experience.
