10-24-2025 05:48 AM in
Galaxy S- Mark as New
10-24-2025 06:34 AM in
Galaxy SOne UI V7.0 update on my S23 Ultra was definitely not a "debacle"!
Did you update Samsung Home, and all the other apps installed on your device?
Did you try Booting into Recovery & Wiping Cache?
If you're having issues with One UI V8.0, maybe backup your device with Smart Switch & Factory Reset.. That's what I ALWAYS do after EVERY Android Version / One UI update.. never had any issues with updates.
10-24-2025 06:46 AM in
Galaxy SHi SweetDean,
We are sorry to hear that you are experiencing issues with the widgets on your Galaxy S23 Ultra following the latest update . We recommend that you try the steps suggested by RedDogRabbit and verify whether they help resolve the problem. If the issue persists, please consider reporting it through the Samsung Members app so that it can be addressed in a future update.
10-24-2025 06:51 AM in
Galaxy SYou also might want to check if you have the October Security Patch on your S23 device.. There was an initial release of One UI V8.0 for the S23 series, which was paused after some bugs were reported. Samsung has released a new update for your device with the October Security Patch.
