Wifi problem
(Topic created on: 12-16-2023 07:16 AM)
shaneomac
I am having some issues with my samsung s22 ultra..
Everytime I close my phone and repoen it the wifi keeps disconnecting
Any suggestions on how to fix this??
 Thanks!
9 Comments
RedDogRabbit
Start with Resetting your Network Settings. Go to Settings & Search for "Reset".
Reboot your Router.
See if that helps.
Not applicable
Go into your wifi setting and go to intelligent wifi and turn "Prioritize real time data" off and turn off "Switch to better WiFi networks" 🙂
Not applicable
Also disable "turn on wifi automatically" and disable "wifi power saving mode"
RedDogRabbit
Thing is, none of that should be necessary. The WiFi Settings on both my devices, include all the things you are suggesting they try turning off.. They are all enabled on my devices. I have zero issues with WiFi.
I'm thinking that there's something else going on here.
Not applicable
This is what worked for me.
RobertZ
Maybe disable WiFi calling?
shaneomac
I tired everything above and it still cuts off overtime I open my phone 😒
RedDogRabbit
You tried Safe Mode?
Helenna
Hi, I request you to please take the help from the given link and perform the given steps.
https://www.samsung.com/ca/support/mobile-devices/how-to-troubleshoot-a-galaxy-phone-that-wont-conne...
