Highlighted
Alright, since my last post clearly was too much for people's emotions, let's try again more delicately.
Okay boys and girls....does anyone else notice when they try to use their wireless power share feature, it never connects? I can out my watch in any spot possible, and it always tells me to move to the center. There are only so many centers in a given space. It's the same with different phones and different watches.
Anyone else noticing this problem? I'm using an S10+.
2 Comments
Highlighted
could be dependent on your watch , or either a bug with the powershare feature, i never use it so I am not much help
Highlighted
Hi brandanct, Wireless charging efficiency depends on distance between wireless charging coils embedded in the devices. The location of the wireless charging coil may vary by device model. We need to adjust the devices to connect with each other properly.
Also, it is recommended to remove any accessories and cover being used before using this feature.
