Fuzzyyyy
05-14-2020 07:23 AM in
Gaming Hub
Hi. Anyone here have the same experiences with me when playing Mobile Legends with the sound being low even though its already in Max volume?
Anyone knows how to fix it?
2 Comments
Jkcrpz
05-14-2020 07:33 AM in
Gaming Hub
hi sir you can use the earphone to better sounds then you can on the dolby atmos
Keissler
05-14-2020 08:55 AM in
Gaming Hub
I also experiencing that kind of problem. The solution I find is that you need to go to game optimizing service in your phone settings then click the storage part then clear data you will see the sound will be louder when you play ML. Im using Samsung Galaxy J2 Pro 2018
