Billditwell
Home Appliances
Just recently our wash machine has started to go out of balance at the end of the rinse/spin cycle. The tub violently thrashes from side to side just before  the machine stops the cycle. It happens with the smallest of loads and on any was program. Rearranging the cloths does not fix the problem. The machine is on level floor and the the feet are all adjusted such that there is no movement of the machine when I try to rock it from side to side. On most occasions there is no error code displayed. Sometime a ‘Ub’ (might be a U6) is displayed but very rarely. The machine has never been a problem in the past on any wash program until it started this behaviour about 6 weeks ago. Does anyone have any ideas? Thank you.
Bill
