06-06-2022 09:27 PM in
Home AppliancesMy hard-wired remote shows the actual room temperature but the temperature reading on smart things shows around 5 degrees warmer which stops the heater turning on. How do you program the thermostat on smart things to read the same as the wired remote control? I have the WiFi kit 2.0 connected to the ducted split system.
06-07-2022 02:05 PM in
Home AppliancesHi there, thanks for reaching out. Could you confirm a few details:
1. Which model heater/air conditioner are you using?
2. Which mobile device are you controlling Smart Things from?
3. Which Wi-Fi kit are you using? Is it Samsung or another brand?
11-04-2022 01:14 PM in
Home Appliances
