Samsung S10 Battery Draining Issues
(Topic created on: 04-25-2020 10:26 PM)
Gelotissimoz
Others
VERY DISAPPOINTED. Because of the new update from S10, my battery drains too fast even if I'm not using it. I also tried the factory reset and it was the same. I lose 6% every 6hrs.
Hoping SAMSUNG will fix these issues like what Apple did when the issues on the battery where it drains faster after the new update was installed.
It's like you’re forcing your consumer to buy a new device in the event that we don't want the new updates that affects the battery system.
Please give us back the UPDATE supporting our LONGER and STRONGER battery for our devices. I've been using Samsung for almost 20 yrs and I believe you can fix it.
Thanks
Gelotissimoz
Others
nag reset ako ganun padin nangyari wala na nga lahat ng apps ko same issues parin
Gelotissimoz
Others
same issues from my previous note 8 after update bumilis na yung battery kaya napilitan na ako magpalit
Shanee
Others
yang link po na sinend ko may mga steps po diyan. after ko sundin kumunat naman po battery ko.
Others
ano po bang reset tinutukoy nyu po ? yung factory data reset po ba ?
Others
nag reset ako ganon padin mas mabilis pa nga nag drain huhu
Others
even in my j6+ phone the battery of the phone was so fast to drain even I'm not used it . is it normal ? or it's there improvement of software.?
Gelotissimoz
Others
because of the update
Others
yeah maybe due to updated of software , but I'm worried on my phone , I off the screen of the phone and for minutes I open it . then the battery bar are drain so fast even if I off the screen and also I'm not used it
Gelotissimoz
Others
exactly!!!
Others
shanne ano reset po para reset ? factory data reset po ba yung tinutukoy mong reset ?
