Battery Draining?
(Topic created on: 10-16-2019 08:04 PM)
badmark
Questions
Anyone else seeing extreme battery draining on your S10 device and or your connected Samsung watch?
Before beta my phone would last at least a day and a half if not two but now I can barely make it through one day with roughly an hour and a half to 2 hours of screen on time.
9 REPLIES 9
stlboi
Beginner Level 3
Questions
I've noticed battery drain but not that extreme
Questions
yea my battery drain ain't that bad but within the beta, I would expect better battery life
DickB
Questions
I have an S10e. I always check my overnight (6 hours) drain and the 5% drain is the same as on Pie. My first day showed 4.5 hours of SOT, down about an hour from Pie, but I opened every app and setting to check out the update, so that is probably low. I'll have a better idea after a couple of days to let my use and the firmware settle down.
jmcphail31
Questions
yes I have been having the same issue
OMNISCIENT
Questions
Fact:
I already raised this question, and sent already my BETA FEEDBACK in the right channel, for them to fix this.
By the way, those amateurs and fanboys will tell you "I don't have ANY problems in my S10 battery life, and if you do, downgrade to Android 9 now".
Message Samsung directly in the BETA feedback channel.
Have a great day
Tel864
Questions
Yep, mine is a little worse also. I also remember the first beta or two killing the battery on my S9.
FutureNobody
Questions
yes I have noticed but this seems normal due to it being a beta.
Dan221
Questions
i factory reset my phone after installing beta and haven't had issues with battery life. seems to be the same as before if not a bit longer battery life. also have my watch on all day.
SamsungUSABetaTeam
Questions
Thank you for your post. We appreciate your contribution to the Beta community.
