Resolved! Solved
Always on display. Need help..
(Topic created on: 07-10-2024 08:31 AM)
Lukas234
Solutions & Tips
My s24 ultra isnt displaying landscape mode option. My phone is a business phone so it is run by an organization. If someone could help with getting landscape mode for AOD. Thanks.
My phone is completely up to date.
awesamm
Solutions & Tips
If you hold the rotate icon on drop down menu, it should give you options for landscape mode in lockscreen.
5 REPLIES 5
awesamm
Solutions & Tips
Lukas234
Solutions & Tips
It worked, thanks a ton!
Helenna
Solutions & Tips
Hi Lukas234,
We are good to see that awesamm suggestions worked for you and your issue has been resolved.
Please take the time to accept the comment that you find helpful as a solution by clicking on 3 dots and tap on "Accept as Solution" and help others with the same query.
Thank you awesamm .
Lukas234
Solutions & Tips
Thanks Helenna
Banting
Solutions & Tips
I cannot find the rotate icon to change from portrait to landscape mode. It used to be on the pull-down menu, but now it's gone. Any help would be appreciated.
