06-13-2021 03:20 PM in
Wearables- Mark as New
06-13-2021 08:00 PM in
06-14-2021 03:54 AM in
06-14-2021 04:05 AM in
WearablesHi, I suggest you to inspect the earbuds for dirt and damage. Be sure to regularly clean the earbuds. The build-up of dust, earwax, or other debris in the earbuds can make it difficult to hear. Inspect for a cracked or lifted case, and broken bent, or lose parts. If you see obvious damage, cracks, or small chips on the earbuds, this means that the earbuds have suffered from an external impact. This can impair the earbuds and their functions. The earbuds are not impervious to water damage in any situation. Exposure to water, liquids, or chemicals can cause damage or issues with the earbuds. Restart both devices. If you continue to experience problems, restart the earbuds, and then make sure the earbuds software is up to date.
