Buds3 Pro ANC Amplifies Wind Noise
(Topic created on: 09-28-2024 11:47 AM)
Ddegeorge
Wearables
I am wondering if anyone else has this problem. When I am using the Buds3 Pro outside, even the slightest wind gets amplified by the active noise cancelling (the opposite of what I expect). I have gone through all of the settings and it is worst when active noise cancelling is set to the highest setting. Music and audiobooks are EASIER to hear when ANC is switched completely off in light wind. A bit disappointed because this was never an issue with my Buds2 Pro.
2 REPLIES 2
Troubadour
Wearables
Try Googling the problem, you tend to get more solutions there.
bobbybobrob
Wearables
Mine arrived on Friday, I used them at home indoors and they were amazing. The ANC blocked out a lot of the sounds like the washing machine. I used them the next day outdoors, for walking, and I'm having the exact same problem as you, there is constant wind noise. It wasn't even windy, just a light breeze. I'm so annoyed. I don't get why there aren't more complaints about this. I had the same problem with a pair of Nothing Ears that I bought, and ended up returning them. No way am I keeping these with all that wind noise.
