Earbuds 3 pro & Earbuds 3
(Topic created on: 11-18-2024 10:13 AM)
A4109
Wearables
I got the earbuds 3 but noticed the noise cancelation is not working properly now i want to go for the earbuds 3 pro. I want to know if the noise cancelation works fine before getting it. Or better still if i can go back to galaxy buds 2 pro
5 REPLIES 5
Helenna
Wearables
Hi A4109,
If you don't wear the earbuds properly, they may not work. Try to wear the earbuds properly again so they fit tightly without space between your ear hole and the ear tip.
The ANC is significantly improved over the regular Galaxy Buds and Buds 3. The Buds 3 Pro offer intelligent ANC, which adapts the level of noise cancellation based on your environment, giving you a more tailored experience.
The sound quality and comfort are also top-notch, making these a solid choice if ANC is a priority for you.
If noise cancellation is your number one concern and you want the best available, Galaxy Buds 3 Pro would be the most reliable choice.
However, if you’re looking for a slightly more affordable alternative with still great ANC performance and superb sound, Galaxy Buds 2 Pro would likely serve you well.
Thank you.
A4109
Wearables
Thank you for your kind response
Wearables
It is hard to say how good is the ANC. Maybe I can try describe below. The ANC of Bud3 Pro, works fine in most situations. However, some extreme situations are not working at all.
If you are using your Buds in:
- construction area
- while mowing your lawn
- using blower
- sitting beside an AC (Outdoor)
...etc.
But works for me while I am at shopping mall, coffee shop, friends chatting each others, I have no issue with ANC.
LKCyber
Wearables
I have the Buds 3 Pro, but I have also started noticing that the ANC doesn't work too well by itself unless you have something playing on your phone. I could literally hear my own finger snaps from arms length even and songs played on my laptop while my buds were connected to my phone. I could hear pretty much all of it.
Tried resetting and new update plus pair/unpair and restart as well. No change
A4109
Wearables
Thank you for this feedback
