Frequent disconnection of buds 3 pro with s22 ultra
(Topic created on: 12-18-2024 04:28 PM)
Ja551e
Wearables
Hi when i am listening like from youtube music or youtube or spotify , my buds3 pro keep disconnecting midways after sometime dont know what is causing issue.
It only happens when i use onw buds if i put both buds no disconnection
6 REPLIES 6
RedDogRabbit
Wearables
It could be the Bluetooth connection between the Buds & and the phone.
You could try Unpairing & Pair them again, or you could try Resetting the Network Settings.
Also check to see if there's any update for the Buds.
One of those should help.
Ja551e
Wearables
There is no update yet. Fortunately, it never drops when playing pubg for 3or4 hours continues
RedDogRabbit
Wearables
Sorry, I missed the last bit where you said that it only disconnects, if you're only using one Bud.. right?
It's possible that is by design.. on the Earbuds side?
In other words, The Earbuds may be waiting for the second Bud to get connected?
Ja551e
Wearables
Idk with one buds its already playing music, as other bud is in case, and suddenly it disconnects its strange
RedDogRabbit
Wearables
I think that most Earbuds are designed to work with BOTH connected.
If they don't disconnect when you are using both, that's your answer.
Helenna
Wearables
Hi Ja551e,
Yes, as adviced by RedDogRabbit, Resetting the Bluetooth connection or network settings can often resolve issues like this.
You can also try Restart your phone and the earbuds to clear temporary glitches.
Power off your phone and turn it back on. For the buds, place them in the charging case, close the lid, and wait for a few seconds before using them again.
Thank you.
