Galex19
08-11-2022 05:36 PM in
Wearables
Hello, I had my Galaxy Watch 4 (44 mm) almost 2 months ago. And I notice that this watch doesn't last even for two straight days and Im just using it as a regular smart watch (not in heavy using yet like doing excercises, etc). Do you experience the same? Is it really the capacity of this watch? I don't wanna compare because I also have my Huawei GT 2 and even with heavy usage it still gives me 4-7 days of battery life. Just kinda upset that I charge my Galaxy Watch from time to time. Hope you could help me on this.
Solved! Go to Solution.
08-11-2022 05:59 PM in
Wearables
No worries, I suggest you charge it before you sleep to keep it fully charged. It will also make your device last longer. 😊
If you find my comment as a solution to your question. Please click the triple dot and choose "Accept Solution" as a sign. Thanks! 😊
3 Comments
08-11-2022 05:47 PM in
Wearables
Yeah, that's normal I actually have the Galaxy Watch (2018) and I usually charge it between 2-3 depending on usage. 😊
You have to understand that your Huawei GT 2 it has a battery size of 455 mah compared to the Galaxy Watch 4's 361 mah. Also the GW4 has superior hardware in terms of memory, chip and Gorilla Glass. 😊
Galex19
08-11-2022 05:55 PM in
Wearables
I thought it was my watch only. Im not just used to charge my watch like every 2 days. Thank you for the response.
Wearables
