Galaxy Watch AOD sound help
(Topic created on: 03-31-2022 11:18 AM)
shase
Wearables
My galaxy watch 4 classic 46mm is using a watchface with an AOD theme as well. Maybe a week ago, my watch suddenly started making sounds every time the watch screen turned off into AOD mode. It sounds similar to the lock sound my s20 ultra makes when I turn the screen off.
I've tried all I can think of to turn it off but I haven't been able to find the solution.
I've tried different themes, both native and 3rd party, but no matter what I change the sound persists.
If anyone has a solution, please let me know. Thank you.
3 Comments
TyDe
Wearables
Hi mate. Try this. On your phone. Go to galaxy wearable.
Sound and vibration, system sounds, then turn off unlock or others.
SamsungLaura
Wearables
Hi @shase, that's strange. If this doesn't work, please send through an error report via the Galaxy Wearable app for this to be looked into.
To send an error report for a wearable, follow these steps:
  1. Go to Galaxy Wearables app > click on the device desired on the side menu
  2. In the side menu, tap Contact us > Error reports (in the Get help section)
  3. Fill in details and the frequency of the issue that you have with the wearable.
  4. Click send.
Yuriez
Wearables
What problem do you have a solution for now?
