07-02-2021 11:20 AM in
Wearables- Mark as New
07-02-2021 11:29 AM in
WearablesHi, The Galaxy Wearable app connects your smartwatch to a compatible phone (Android 5.0 and higher). Use the app to manage and monitor your watch's features and apps installed from the Play Store. But first, make sure Bluetooth is activated on your phone.
First, open the Galaxy Wearable app on your phone, and then tap Get started.
Select your watch and then follow the on-screen prompts to complete the setup process.
While connecting your smartwatch with your phone you'll see prompts to activate your carrier's service on the watch.
If your watch has this service, follow the prompts to complete the activation process and finish setting up your smartwatch.
To connect an additional device, tap the Menu icon (consisting of three horizontal bars) on the top left side, tap Add a new device, and select your device. You can switch between devices whenever you want.
Note: If needed, you can access accessibility settings from the Welcome screen on your smartwatch or fitness band. Also, if you have accessibility options set up on your connected phone, you can set your watch settings to match the phone.
