John41922
Wearables
Is there anyway that I can locate my watch if it was stolen? Thank you
5 Comments
Wearables
Through SmartThings app of Samsung you can view via GPS map. So long as the watch has battery it should be tracable.
Khaled75
Wearables
Does it even support Samsung Gear series?
Wearables
Most likely as the Gear S2 was released 2015, while my Galaxy Tab 10.1 which was released 2011 is still listed on my SmartThings app.
Khaled75
Wearables
Ok. So SmartThings Find supports Samsung Gear.
Sam-TheRightCareGuy
Wearables
Hello John41922,
Hope you are getting your expected answer; please do not hesitate to click the ACCEPT AS SOLUTION button in your next reply.
